remote start reset
  • 4
Nothing at all, as in the lights don't flash and it doesn't respond in any way when you try to remote start?
The most likely cause is that there's a kill switch that's shut off, or the hood safety switch has a problem and the unit thinks the hood is open.
valet switch is a small black push button... but depends on the installer where it was put or if there is even one there... it sounds like the neutral safety switch is not connected properly or is not grounded
depends... fuse box... at the bottom of a dash panel... next to the led... zip tied high up in the dash... zip tied low in the dash... just look around everywhere... the plug is a blue 2 pin plug that plugs into the alarm... now for the neutral safety switch... its a black & grey wire usually
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
343
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Flipx99
Violator of Terms
Flipx99
Building 100
Slody4Futbol
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
