req makes his VW GTi infinite baffle with IDQ15's PICS :D
It's already done now, but it you wanted a LITERALLY tight a fit as possible.
Tape off the hatch with 2" masking tape, as well as back seat. (Where the baffle meets up).
Place un carpeted baffle in place, and use bondo to form the edges to the panel even better than when you fiberglassed. Take off, sand.
Then, I'd personally recommend a vinyl, allante vinyl. Something to match your interior.
Looks solid Andy.
nG
i was actually going to do that noah. but i was out of kitty hair. i was grumpy, and i do have some nice black vynl under my bed. but i dont have a sanding block and it was a ***** and a half sanding that **** with a little 3m rubber block and 40 grit. maybe if i had an orbital DA i wouldnt have minded as much //content.invisioncic.com/y282845/emoticons/pissed.gif.9f665f96bc89e98e708dabd4580bb591.gif . i dont have a nice place to sand. its just a big pain in my ass to work on this **** where im at if you know what i mean. i still think it turned out real clean though.
Why would you play them with the hatch open? You risk unloading doing that don't you?
was not full tilt. but if i turn it up all the way im sure they would protest. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
and jason. ill take a new vid just for you with the whole hatch //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
what song do you want to hear? me so horny by 2 live crew?? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
wee.
h701 installed.
Probably a dumb question but a question none the less, why are you using 2 HU's??? Or is one a DVD or something special???
Jon
one is the HU and one is the controller for the H701 (processor)
the processor has time-correction, EQ, phase, x-over, and other multi-channel 5.1 settings. The controller is needed to adjust any of the settings on the processor, unless you have an Alpine HU control the processor.
headunit;
http://www.crutchfield.com/S-qNODGREfewJ/cgi-bin/ProdView.asp?g=300&id=detailed_info&i=500CDA9830
processor controller;
http://www.crutchfield.com/S-qyTe44eXtie/cgi-bin/ProdView.asp?g=168450&I=500RUXC701&search=h701
processor brain;
http://www.crutchfield.com/S-qyTe44eXtie/cgi-bin/ProdView.asp?g=168450&I=500PXAH701&search=h701
as stated, its an active 5 way crossover, 6 channel 1\3 octave eq, dolby 5.1 decoder, 6 channel time alignment and some other crap //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
channel 1 (output 1\2 for highs) = front 1
channel 2 (output 2\3 for mids) = front 2
channel 3 (output 3\4 for rears im not using) = rear
channel 4 = center\sub
channel 5 = sub (bridge 4\5 with the controller)
so its real REAL versatile. you just need a double din or some other place to mount the thing because it is the volume controll and everything. real easy to use once you get used to it. you can eather set EACH SPEAKER's eq\xover\time align... or you can set each channel (output 1, output 2 ect) together each pair of speakers have the same settings. theres a bunch of 'save spots' (1-0 buttons) so you can have an eq\xover\time align to suit different music and so on.
and it looks super sexy. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
alarm is in the works. fixing car, getting new tires, new horn bodies, alarm.
sigh. i need monies. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
TreyE. if you are gonna post **** like that. get out of my thread and do it in the lounge.
ill get a new false floor cover and re-wire all that **** up this weekend i think. cut the panel to fit the amps and ****. should be fun.
where's all the good pics at? Lets see that processor and all the great sounding SQ mumbojumbo. Make sure to take a grip of pics of the processor... i'm really missing mine while its replacement is on the way.
too bad you're not in CA. I really like to take a listen.
i really gotta clean up the wires man lol. i didnt take any pictures sides these;
ill take some fun ones this weekend i promise. and i have a surprise for you all tomrrow that has to do with a big speakerwoofer.
its a suprise though //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ill also hook up the external mic so i can do time alignment tomrrow too. i have a neat little
spot to hide it in //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Don't get me wrong I've built a few boxes myself and I love doing it and it would've been preferred. But I now live in a one bed room apartment...
42
9K
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
Unfortunately barly someone does these things in my country, and the ones that do, makes it so expensive to test it or even fix it that testing it...
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
I would clean the paint off that location and use two washers to sandwhich the ground wire to secure a solid connection and use a bolt rather than...
27
req
am a mod.
req
Syracuse, NY
Megalomaniac
    May 31, 2024
    May 24, 2024
