RF Punch 200 X2 Trans-Ana
  • 2
Sean Morrison
Rockford Fosgate Punch 200x2 Trans-ana
Tested and works flawlessly. No static, hums, pops, crackles - just pure clean music. The warranty sticker is still intact. The outside shows its age, but could easily be touched up.
At 14.4V voltage this will put out:
500 watts at 4 ohms mono bridged
or 150 x 2 at 4 ohms stereo
or 250 x 2 at 2 ohm stereo
$175 shipped.
UPS Ground
View attachment 26528400View attachment 26528401View attachment 26528402View attachment 26528403
These amps were at the top of the food chain when I got into car audio back in 94 along Phoenix Gold!!GLWS as awesome as this amp is just not enough power for me.You shouldn't have any problems selling this amp!!
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
831
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
Sean Morrison
Sean Morrison
Peoria, IL
Rolltidetbw
    May 24, 2024
    May 23, 2024
