# Rubicon Series 4-Channel Class AB Car Amplifier
# RMS Power Rating:
* 4 ohms: 100 watts x 4 chan.
* 2 ohms: 150 watts x 4 chan.
* Bridged, 4 ohms: 300 watts x 2 chan.
# MOSFET PWM power supply
# Platinum 4 AWG power block
# Midnight blue finish with brushed accents
# Selectable bass boost (0, 6, 12 dB at 50 Hz)
# 4/2-Channel operation
# Speaker-level inputs with signal sensing for automatic turn-on
# High and low level inputs
# IDI (Intelligent Distress Indicator) for thermal, short, and impedance protection
# Turn on/off delay
# Heavy duty aluminum alloy heatsink for heat dissipation
# Tri-mode capable
# Nickel-Plated RCA level inputs
# Nickel-Plated screw terminals
# Infinitely variable crossovers with multipliers
# Variable high-pass filter (15-4000 Hz, 24 dB/octave)
# Variable low-pass filter (50-4,000 Hz, 24 dB/octave)
# Frequency response: 10-35,000 Hz
# Signal-to-Noise Ratio: 105dB
# THD (Total Harmonic Distortion): 0.02%
# Damping Factor: >250
# Signal Voltage Range: 200mV - 6V
# Power Voltage Range: 11V - 16V
# Dimensions: 15-3/8"L x 8"W x 2"H
# 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
