chevyboy91 10+ year member Member 75 0 Naples, Florida, United States Aug 30, 2011 #1 in your oppinion which would be better the SA12 d4 or AQ HDc12 d1, an why ill be pushing them with a AQ2200d Click to read more...
Buck 5,000+ posts little alien on campus 33,682 3,930 Inside of a pyramid Aug 30, 2011 #2 Pair of woofers?
OP chevyboy91 10+ year member Member 75 0 Naples, Florida, United States Aug 30, 2011 Thread Starter #3 yeah either 2 sa12s or 2 hdc12's
Buck 5,000+ posts little alien on campus 33,682 3,930 Inside of a pyramid Aug 30, 2011 #4 With that power, I'd do 2 sa-12's.
OP chevyboy91 10+ year member Member 75 0 Naples, Florida, United States Aug 30, 2011 Thread Starter #5 yeah that was my original plan then i was thinking that id do my sub stage all AQ if i could get a deal on some used hdc's.
Buck 5,000+ posts little alien on campus 33,682 3,930 Inside of a pyramid Aug 30, 2011 #6 You would be better off going with a different woofer than the HDC3 on that power.
Vossy 10+ year member CarAudio.com Elite 1,534 0 St. Cloud MN Aug 30, 2011 #7 HDCs would want more power than that
OP chevyboy91 10+ year member Member 75 0 Naples, Florida, United States Aug 30, 2011 Thread Starter #8 ok. thanks for the input
Kangaroux 5,000+ posts I put on 10,170 0 Maine Aug 30, 2011 #9 On that power I would either do the SA's or a single 15" or 18" HDC
OP chevyboy91 10+ year member Member 75 0 Naples, Florida, United States Aug 30, 2011 Thread Starter #10 i think im just gonna stick with my original plan. 2 SA12's but while i have this thread up i got another question i have a Aq2200d should i get 2 d2's or d4's and why?
wenn_du_weinst 10+ year member CarAudio.com Veteran 4,726 1 ******* Aug 30, 2011 #11 lols ''bigger motor means non efficient'' stupid *** rumor. the AQ's will beat out the SA's on same power. I'd run stuff made from a non Chinese country though.
LosIsATool 5,000+ posts CarAudio.com Veteran 18,504 4 Pensacola, Florida Aug 30, 2011 #13 dual 4s so you can get a 1ohm load. Use this http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22
AllDayMJ 10+ year member VR4 power. 579 0 Salina, KS Aug 30, 2011 #14 2 d4's Rockford Fosgate® - Woofer WiringWizard
09civic 5,000+ posts CarAudio.com Veteran 7,006 0 Melbourne, FL Sep 1, 2011 #15 better have the electrical to support that
