Skar skv2-1500.1d
  • 4
Dolejh
I’m a little confused by the ohms etc. got a skar skv2-1500.1d
4 ohm 500x1
2 ohm 930x1
1 ohm 1700x1
Two skar subs svr-12 dual 4 ohm 800 RMS / 1600 peak
does that mean if I run and wire the amp for 1 ohm I could deliver 850 to each sub?
I think this amp is two small for these speakers - am I right? Should I be running two of these amps or drop down to a lower RMS speaker?
Yes, wire the 2 subs to a 1ohm final load.
They will get 850 each.
That amp is great for those subs.
RMS matches up almost perfectly.
Set your gain correctly and see how your car's voltage holds up when you start to turn it way up.
Do the Big 3, make sure your ground location is a good one, and your wire connection points are rock solid.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
324
806
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
984
Dolejh
Dolejh
Jacksonville
some dude
    May 24, 2024
    May 23, 2024
