sony xplode
  • Thread starter <needamp>
  • Start date
  • Replies 8
  • Views 3K
Hmm single voice coil 8 ohm. Thats going to be tuff to get an amp to push it loud. If you get another sub you can wire them in parallel thus yielding a 4ohm load, which almost any amp can push easy. Then all you need is a 200 to 400 watt amp. Look at mtx amps.
i owuld recommend taking that sub back, if you can, and seeing if they had a 4 ohm version, or like speedygolf said, invest in another sub to get more power from the amp you are gonna get...
dont get npther, just go back and get a 4 ohms sub, if you did get another sub, yopu copuld have a 4 0ohm load, but it doesnt matter because youd still be giving each sub very little power, unless you spend lots of money for a amp that does 800 at 4 ohms bridged. you could get a RF punch 800.2 for about 315 and bridge the amp to the 2 and have 500 or so to each sub. but then youd have spent extra on 2nd sub and bigg amp. if you had one 4 ohms sub, yopu could stick witrh a small amp like 360.2 or so for under 200.00 and have saved the money on the 2nd sub also, and seeing as you bought a sony sub and only 1, it doesnt sem like yourplannig on competing so it doisnt really matter.
i would junk any thing sony sony used to be a good name in the audio industry but now they **** my sony 5000x head unit has a mind of its own DON'T BUY SONY!!!
Originally posted by :i would junk any thing sony sony used to be a good name in the audio industry but now they **** my sony 5000x head unit has a mind of its own DON'T BUY SONY!!!
I agree, sony does not make good car audio eqipment.
i would like to disagree. i have a sony x-plode HU and have not had any problems with it. i also have a sony reciever for my home system. i am totally happy with both.
sorry im a idiot i thought it was 8 ohms but it acutaly is 4 ohms . 450 watt , so what kinda amp do u think i should get i dont really have enough money for another sub right now
818
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
967
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
Guest
    May 24, 2024
    May 23, 2024
