Soundstream Rubicon RUB2.600
FasterThanYou
i'm kind of a big deal
9/10 Cosmetic. Works perfect, just took it out to run 4 ch active.
Local pick up in Socal
MS Power @ 4 ohms 180 watts x 2 channels
RMS Power @ 2 ohms 300 watts x 2 channels
Bridged RMS Power 600 watts x 1 channels
Amplifier Specifications
Amplifier Class AB
Number of Channels 2
Total RMS Power Output 600 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.015%
Speaker Level Inputs Yes
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency 15 - 225 Hz
Low-Pass Crossover Frequency 50 - 800 Hz
Signal-to-Noise Ratio 105 dB
Bass Boost 0 - 12 dB
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 30A x 2
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
FasterThanYou
FasterThanYou
Californication
FasterThanYou
    May 31, 2024
    May 24, 2024
