SOUNDSTREAM Rubicon2 502 USA Old School
  • 2
wanderer1
Laughlin
Item(s) for Sale:Soundstream RUB2 502
Item(s) Description/Condition:4ohm Stereo-100x2, 2ohm stereo-250x2, Stable to .5ohm both channels are bridgeable and amp can run mixed mono (tri mode) without adapter. S/N Ration 100, Dampening greater than 200. High Current/High Power automatically switches depending on ohm load. 24db low pass x-over, 12db high pass. Hawkins bass circuit and subsonic filter. Class A input section, balanced and unbalanced (RCA) inputs, triple darlington outputs, multiple protections. Lots more in the manual about this USA built SQ beauty. 9/10, 4 small nicks
Price: $285
The actual name of the amp is RUB2, it is the second gen of the Rubicon, as it uses newer technologies that were not present in the original Rubicon series and as far as I know the last of the Rubicon series to be made in the USA. The RubCA52 a 102 are the pure class A variants of the original Rubicon line also. The original Rubicon line has a few variants. Hope this helps, as I have yet to gain the skills to make a new Soundstream amp.. If not you can read the original Rubicon manual and the manual for this amp and ascertain the many differences for a better, more robust amp.
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
wanderer1
wanderer1
Laughlin
wanderer1
    May 18, 2024
    May 18, 2024
