Soundstream XXX-6500D VS Sundown Audio 2500d
Joe562MMA
ok i know the sound stream is rated more power but i just want some input from all u guys about rated power about quality of the amp an everything took-en in to consideration..
i am gonna be running 235 amp h/o alt one yellow top optima in front 2 ups 12-370fr batteries in the back 2 runs of 2/0 welding wire to back batteries.. and a set of 4 15 inch alpine type Rs in a box tuned to 29hz
so my question is would i be better running the sundown at .5 ohm making around 3000 im guessing..
or running the subs at 2ohms with the sound stream amp making RMS Power Rating @ 14.4 Volts:
4 ohms: 1750 watts x 1 chan.
2 ohms: 3290 watts x 1 chan.
1 ohm: 4490 watts x 1 chan.
any help or experiences with these amps would help thanks
I don't know too much about either amp, but efficiency at 2 ohms will be greater than efficiency at 0.5 ohms pretty much every time. If you can get them at the same price get the SS.
i was thinking that too ..it would be safer to run them at 2 ohms ..plus the sound stream has dual 0 gauge power an ground connections looks beefy lol
---------- Post added at 12:09 AM ---------- Previous post was at 12:08 AM ----------
lol what are u asking for it ..an Ive always preferred sundown over dc.
ss dtr1.3400 are nice and rated @ .5 ohm. and they are not hogs @ .5 in my eyes. my friend had this before me on his stock 130a alt with 2 2 yella top opti's and he was still able to maintain 12.5v on music, so seeing you have a bigger alt it would probly do well. also they do rated from the clamp thread i seen "taylorfade" was talking about he clamped one... i just got one... i like it but id rather have power @ 1 ohm seeing im not going to a .5 ohm. i wish i could find somone with say a saz-2500 thats looking for .5 ohm power to trade with
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Joe562MMA
Joe562MMA
Los Angeles , CA
bgowdy
    May 31, 2024
    May 24, 2024
