Speedwagon
Up until the other day, I thought my right speaker was just being blocked by all the stuff I had on the passenger side for this trip. I moved all the stuff, and realize the speaker was not playing. Every so often, it will suddenly start playing for a bit.
So I did some troubleshooting. I thought it was probably the amp, since the amp is probably 20 years old. Swapped RCAs, swapped speaker wires. Still the same, right not working. Pulled it apart, check connections, all looked good. Swapped the right to the left, and still didn't play. Must be the speaker itself.
Is the speaker toast? Or is there some easy fix for a speaker that occasionally turns on, and sounds fine? ID CTX 6.5 4ohm speakers.
