speaker wiring help needed
Dr. Slam
Slamming hoes n trunks...
here's the deal: i have an mb quartz dsc 480. ( 80 x 4 at 4 ohms, 160 x 4 at 2 ohms, 320 bridged at 4 ohms ) i have 6 speakers that im trying to wire to this amp. 2 infinity kappa 962.9s ( 110w each at 2 ohm ), 2 infinity references 930.9s ( 110w each at 4 ohms ), 2 infinity kappa 52.9s ( 55w at 2 ohms ). My question is, what is the best way i can wire everything to get the most power to my speakers?
The best thing i could thing of was to wire the 692.9s on they"re own channels and bridge the 930.9s and the 52.9s to 2 channels at a 3 ohm load. Is they're a better way w/o purchasing another amp? any tips, suggestion, and help would be greatly appreciated
Where are these speakers located in your car? I'd worry about amping the fronts and forget the rear. Or just amp 4 and forget the last set. If you must amp them all, then I'd say the 3 ohm idea is best.
is that max or rms speakers ?
confusing reading.
amp
xxx rms@ 4 ohms
xxx rms@2 ohms
speakers
xxx rms x ohms each
ect..ect
Ok me being a car audio newbie, i'm assuming that since i don"t watch movies in the car it wont matter if i mix front and back signals. Will the 3 ohm bridged load kill my amp? and will wiring the 55 watt speakers with the 110 speakers damage the 55 watt speakers with running 320 watts running through em?
I was thinking keep it as a 4 channel and run the 3 ohm load on two of those channels. You'll definitely be ok like that. Wattage can be controlled, just because an amp is capable of 300 watts, doesn't mean you have you use all 300 watts.
575
Parallel at the amp is the same as parallel at the speaker then to the amp. Just like parallel off of a single subwoofer driver with two voice...
appriecate it man! I was so busy thinking about it that I didn't even think I could look it up with a multimeter.
Lower impedance does not burn up speakers...too much power or a distorted signal are what smokes a coil...
Dr. Slam
Dr. Slam
Chicago Heights, IL
Dr. Slam
