SQ Diamond 12" and PPI Amp Special
  • 1
trumpet
Barry Schanz
May Special 12" Sub and Amplifier
Diamond Audio SX124 SQ-oriented 12" subwoofer
Precision Power i650.1 mini amplifier to perfectly compliment the subwoofer
SX124 is an open box display model that has never been powered up or mounted.
Everywhere you look on the new Studio series subwoofer you see some form of metal creatively used to improve performance. From the artfully designed O2 Cast aluminum frame basket to the unique heat dissipating radial heat sink, Studio subwoofers are built for sonic quality and speed. Featuring dual mirror image flat spiders attached to a dual 3″ four layer voice coil applied into an intercooled motor design with vented pole piece ensures that Studio subwoofers can handle the power.
Precision Power iON series
This is a Korean built small Class D series that will surprise you with how much power they can make. This amplifier is new and it was only taken out of the box for photographs.
SX124
Features and specifications:
  • Power handling: 600W Nominal
  • Total diameter: 12.4 in. (315 mm)
  • Mounting diameter: 11.1 in. (281.9 mm)
  • Mounting depth: 6.2 in. (157.5 mm)
  • Sealed enclosure volume: 0.875 ft3 (24.8 liter)
  • Vented enclosure volume: 1.25 ft3 (35.4 liter)
  • Hard anodized aluminum alloy cone
  • 02 Cast aluminum frame with aluminum radiating heat sink
  • Dual 4 Ohm 3″ four layer voice coil
  • Intercooled motor design with vented pole piece
  • Dual mirror image flat spiders
i650.1
  • RMS Power @ 4 ohms: 400W x 1
  • RMS Power @ 2 ohms: 650W x 1
  • Dimensions: 5.375″ W x 1.875″ H x 9.00″ L
  • Speaker level inputs
  • LPF 35 Hz - 250 Hz
  • Subsonic filter 10 Hz - 50 Hz
  • Bass boost 0 dB - 12 dB at 45 Hz
  • Remote Gain Control Included
If you need a quick box solution we offer Atrend high quality prefab enclosures.
$275 shipped
Free shipping to the lower 48 states.
Shipping to all other locations requires a quote.
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
  • Locked
I have aPC250on Ebay right now that works excellent couple days left on it at auction on the cheapies
4K
I am wondering if anyone has heard or have information on the new PPI vertical PC amps. Are they good for a budget sq class D amplifier. Any...
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG,16.2022 @9PM CT THANKS
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
