static from CDA9825
  • 1
half
I just fitted an L.E.D driving light and now my radio has intermittent static.when the led is operating. Had anyone had the same problem?? .I fitted the same light to a previous vehicle the same way with a supercheap radio and that worked fine
The LED light is running through a 5 pole relay and when it is on there is no power required to close any contacts. The contacts are triggered by the dip light wire And the radio works perfectly, without the LED light on.
Try and use the factory ground wire in the harness instead of chassis ground to see if it makes a difference
889
I was listening to music one day and after pausing it on my phone (i was using Bluetooth) there was a very present static, It has been working...
Sounds like HU, but I'd try hooking up the speakers to a different source as a troubleshooting step. The professional installer who charged for...
half
half
Palmerston North
half
    May 18, 2024
    May 18, 2024
