You still don't understand. Hopefully this will help. Please read it man because it is simply true.
Wattage = Voltage X Amperage and Resistance = Voltage / Amperage
therefore...
If Wattage remains the same, and Resistance increases, Voltage increases and Amperage decreases
The "voltage drop" you are referring to is not analogous to the increased voltage you'd get at a specific wattage by wiring at a higher resistance. This is just "nominal" (if you can call it that) voltage differences from different nominal resistances at a particular wattage.
Edit
voltage may or may not change during music. When you get resistance rise or box rise at a specific wiring (nothing to do with wat I've been talking about) power will likely drop and so will current, but voltage won't necessarily change. It can though, but that has nothing to do with what I was talking about with wiring at different nominal resistances.
YOU do not get it..
Ohms law is correct, but we are talking about an audio system.
Amp 1000 watts @ 4 ohms = 71 amps
Amp 1000 watts @ 1 ohms = 71 amps
From the battery to the amplifier it does not jump up in voltage. From these two points it will pull the same amperage.
The alternator and battery cannot detect impedance drop.
So in reality they both pull the same amperage, but the difference would be is 4 ohms maybe 88% efficient compared to 1 ohm maybe 32% efficient.
This is where all the resistance and all cause a major load on the AMP and send the produced power over to the subs or speakers.
Now if this 4 ohm amp would drop to 1 ohm then it would need more amperage to produce the power it needs. Which is where amperage needs increase.
Ohms law is 100% on electricity, but because amplifiers do not work this way you will not get the same results as ohm laws.
The only different amp that can change this is Brazilian style amps
Sent from my draconis using Tapatalk
