Sub for .3 cu ft of airspace (small box)
Just found out the JBL GTO804 only needs .3 cu ft of airspace in a sealed enclosure. The reason why I have to build 2 boxes is because I am trying to hide the subs and don't want to loose cargo space or my spare tire to do it.
Building 2 boxes that are 11.75" L x 11.75" W x 5.75" H. I am thinking about putting in a JL Audio 6W3v3-4 in each box. Is there a larger sub like a 8" or 10" that would be a better option?
There is prob close to a 100 different subs that are cheaper and better then those JL's.
Try to locate a TC OEM 10 or 12. They wrk great in enclosures as small as .5cf and are rated at 800rms each.
I am going to be using the 3rd and 4th channel on my MB Quart ONX4.125 to power these two subs so I don't want anything that is power hungry. I am thinking the JBL GTO804 will fit my needs just fine.
6.5's are good for midbass and will not work well if used as a sub. What ohm load can you wire 2 of ur channels down to on ur amp? Might be best to bridge 2 channels and just run 1 8"..
NM i looked it up best bet would be to bridge 2 channels @4ohm which will give you 500watts. Due to ur lack of cf space I would go with 1 of woofercookers sa-8's for $100 shipped. Freshly reconed and would do well with the power you have on tap and can wrk in small enclosures.
445
465
573
701
cody0707
cody0707
Tallahassee, Florida
disturbed471985
    Jun 1, 2024
    May 31, 2024
