sub sonic frequency question.
  • 6
do you mean lowpass filter or subsonic filter? I can see a lowpass filter set at 80, but not a subsonic filter
Don't listen to Will, he knows not of what he speaks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'd set your LOWPASS filter for about 80 hz. The subsonic, should be 20hz or lower, and only if your enclosure is ported.
Kef
Kef
"I must BREAK you" //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
where chu been at?
253
407
515
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
829
531
mlocke32425
mlocke32425
florida
pjhabit
    May 18, 2024
    May 16, 2024
