sub sonic frequency question.
  • 6
There's nothing wrong w/ using a sub sonic filter w/ a sealed enclosure, I've got mine set @ 28 Hz. Most music won't have much (if any) information below that point anyway. Even if there was, it wouldn't be audible to most (aside from the resonances produced from shaking apart your vehicle). Using the SSF will also shrink the bandwidth of frequencies the sub has to produce- making it more efficient.
253
407
515
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
829
531
mlocke32425
mlocke32425
florida
pjhabit
    May 18, 2024
    May 16, 2024
