sub wiring
  • 3
I feel like its eaier to wire the way I drew up. You only have to fit one speaker wire for each positive and negative connection vs more than one the way 12volt shows.
A little DAP will do ya, drill, feed & seal, done.
699
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd...
blowthemup
blowthemup
North Carolina
Slo_Ride
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
