SUBWOOFER WIRING DIAGRAMS II
  • 2
I have another question about wiring subwoofers. If you have 4 subwoofers DVC 4 ohm and you connected them to a mono channel amp of the proper power for all 4 subwoofers and instead of connecting all 4 in parallel and or in series with one another and connected each positive (2 positive wires and 2 negative wires for each subwoofer) what would the end load be as in ohms of course?
Not sure what you mean when you say "not tied to each other. " If you have a mono amp(one channel), then your wiring will terminate at the one...
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
994
No. Those are speaker level inputs from the subwoofer. Lower frequencies should go to the subwoofer. The other front and rear speakers carry a...
10
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
brockjames4
Phoenix, AZ
    Jun 1, 2024
    May 31, 2024
