Central Region Sudden Impact Sound Show/ Meca 2x in Alsip IL May 15
IA,IL,IN,KS,MI,MO,MN,NE,OH,OK,TX,WI
SHOW HAS BEEN MOVED TO 3350 CALUMET AVENUE, HAMMOND, IN
Because of the weather.
If anybody can get ahold of the DTF guys that are coming up, I'd appreciate it if you can tell them the new address (this is where the show in april was).
Though I don't think it's going to be a MECA show anymore.
Is everything still on for tomorrow? From 12-3 but in the indiana location now?
that post was in reference to the original show on the 15th which was rained out, so they moved to hammond as it's an indoor spot.
22nd is in Alsip and goes from around 11-5, not sure why they advertised it as 12-3. I called the shop last week to confirm since I won't be there until about 3:00...
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
Check each speaker for shorts. A pinched wire grounding out or a individual blown speaker can sometimes make the internal amp go into protection.
7
They're rated for 250wrms, so you were overpowering them, especially the poor 10s. XBL subs sound really clean at their limits due to the flat BL...
10
351
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
tommyk90
THE WHOLE THING!!!
tommyk90
Chicago Heights, IL
mlstrass
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
