Suggestions for a remote start....
Colt9699
Rockstar
1,977
Erie Pa
I am going to buy and install a remote start in my wife's mini van as a gift to her.
I need suggestions on models and prices(features and such).
Will I need relays for the lock/unlock feature?
Starter must do 2 things lock/unlock doors and obviously start the van.
Van is a 1999 Mercury Villager
I would like to keep the price reasonable.....
I found this one, but says I will need extra parts for keyless entry.
Viper 160XV 239.99 MSRP
http://www.viper.com/security/viper/viper_rs.asp
it says "maybe required" how much expireince do you have with remote start?electronics?
The extra parts would be as you said relays, incase you have a 5 wire locking system and also you might need a relay to change to polarity of a wire
With that remote start in a 99 Villager, you won't need any additional parts for keyless entry, but you'll need an additional relay for the remote start to power a second accessory wire. You'll also need a relay if you want the dome light to come on when you unlock the vehicle with the new remote.
Thanks fellas
I have very limited experience with remote starts....
I have installed exactly one of them...an Ungo remote start/alarm a few years ago.
But I do know the basics and how to read so I should get along just fine I hope //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The 160 has an onboard relay for illumination. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thanks fellas
Keep in mind Viper/Clifford and Python are not to be sold "over the counter" or via the net. Dealer installation is also Required. Without it your warranty is voided.
If you do pursue it anyway, let me know if you need the wiring diagram for your vehicle.
the 160 does not have an onboard relay for dome supervision. no viper remote start or security does. you must use a relay if you wana dome supervision. it is a 500 ma output.
Also for that price, would include installation at best buy for instance. and wouldn't void any warranties.
Brain fart on the 160, your correct it does not have an onboard relay for it. Although not correct on none of the alarms. I did a 1000 the other day so it was stuck in my head. As well as the older 600s having it onboard as well.
Price is irrelevant. If He is installing it himself, then the warranty is voided.
BTW its only a 200ma output not a 500.
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
560
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
4
426
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
You might get some inspiration from the install that I did... Delta Audio Install
11
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
656
Colt9699
Rockstar
Colt9699
Erie Pa
6spdcoupe
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
