Sundown SD-3 Line : In the Works
I am about to start production shortly on the 10s. The 4th set of prototypes hit the spot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Now I can start on the 12s and 8s for the SD-3 line.
The X-15 makes a pretty nasty sealed driver -- although, I don't think any customers have used them as such yet. F3 of 38 Hz in only 2 cubes sealed.
wow are you serious..!?!? i was talked out of a x15 sealed on another site!!!
slim2fattycake,
The total depth (not just mounting depth) is ~5.2" -- you don't need any room behind the woofer (solid pole) -- and as far as in front it can move forward about 1" but the surround is 0.3" behind the gasket already so you need about 3/4" in front of the gasket.
I'm ready to order //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
slim2fattycake,
Just to make sure, that's 5.2" including the 3/4" travel out of the front of the gasket or is it 5.95" including the 3/4" travel out of the front of the gasket? Is this for the 8", 10", and 12" or which?
Thank you sir you just helped me figure out wha I'm gonna throw in my Buick I need extra trunk space so I was gonna run a eclipse aluminum or a sundown sd. I bought that Porto amp saz1500 clone from the yard sale so that should pair up nicely
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
djr4x4
    Jun 1, 2024
    May 31, 2024
