Swapping Head Units Questions
  • 3
You'll need a new harness for the head unit wiring, yes. This is where those two-piece universal harnesses come in handy - just take off the manufacturer-specific part of the wiring, and leave the vehicle wiring intact.
u won't have 2 buy new if it's the same factory harness... and they were installed with a wiring harness... then you can unplug the gm/clarion harness from one and unplug the gm/eclipse from the other and swap them over
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
6
976
6
140
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
539
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
641
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Breakdancin11
Breakdancin11
Pontiac, Michigan
Slody4Futbol
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
