System improvements
  • 2
jhalbert
ok i went out and bought a rockford fosgate db500.1 amp. So know i have that 2 kicker comp c12s a sony xplod 50x4 head unit infinity reference 5.25 door speakers and optimus 6x9s if anyone has any suggestions on what i can do to improve my system plz tell me thank you.
i would say install everything and see how it sounds. Then you will have an idea what needs improvement and what doesn't. Do you have an enclosure for the subs ?
I agree with Ramos in first listening to your system and then decide where you would like to see improvements made. I have found that a decent EQ can make a huge difference in any stereo system. Also an electric crossover helps tightn up the bass quite a bit, as well as protect your mids and highs from bass frquencies.
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
284
655
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
jhalbert
jhalbert
Stephenville tx
