System keeps killing my battery.. need some advice.. PLEASE!
EGordon_
So I'm running 2 12inch subs in the trunk from a Sony Xplod 1200W amp. For some reason it keeps killing my battery and I've been doing research all morning.
My alternator is aftermarket and puts out 200 amps.
Battery just got replaced and is an interstate battery.. pic attached.
What I drew from my research is that I obviously need a stronger battery, and a two battery set up with an isolator would be my best bet.. as the strong alternator should be able to handle all that.
Please let me know what you guys think or any advice!
I don't believe so.. I bought the car off a guy about 2 weeks ago with the system all hooked up so I am not entirely sure. Big 3 would fix that problem without the need of a second battery + isolator?
I brought it to advanced auto parts the other day and he said that the only way to prevent battery dying is second batt + iso.. I am not the most knowledgable with cars so I've been trying to inform myself through research the best I can
If you have the big three done, and the 200 amp alt as you say you have, and a decent battery(perferb.a min of an Orileys AGM batt)You shouldnt have ANY ISSUES With that kind of supply demand
That's reassuring. So is the battery current equipped up to par or should I return/replace ? Big 3 should fix issue of battery dying?
That battery is actually too small im my opinion for anything over 600rms
---------- Post added at 12:27 PM ---------- Previous post was at 12:27 PM ----------
What vehicle is it??
2003 Ford Mustang, 3.8L v6.
What should the min. battery size/power I should be looking for have? Any specific suggestions/brands?
Make sure something isn't screwy with the remote wire..say the amp isn't shutting off like It is supposed to..
You mean your vehicle dies when not in use right?
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
496
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
969
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
974
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
EGordon_
EGordon_
United States
Jes 42
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
