Taramps help!
  • 5
IndySlim
CoolAssDude
140
19
Omaha NE
Got my Taramps Smart 3k installed and yes its definitely louder. My only issue is not necessarily and issue more of a curiosity about pre out voltage. I know gain is not for bass but I'm clipping @ about 26 on my radio volume depending on the song. I do have a bass knob and the amp won't allow me to kill it unless I do it intentionally hence the name "smart 3k". I'm wondering would I get a little more range out of my volume and or bass knob if the pre out voltage were at the ideal 2 volts that taramps perform well at. Also is there a way to reduce input voltage and no I don't mean turning the volume down. I mean is there a way to permanently make my amp see 2v
first set your amp gain right. heres how. note, the 50hz test tone is at the very bottom...
Set your gains properly. If you're still clipping then you can try introducing a line driver to your system like an Overdrive or Matrix (Audiocontrol) or whatever line driver you can get your hands on to boost the input voltage. Mind you, this won't make your amp play remarkably louder per say, but It will get you out of clip by reducing distortion signals from your input.
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
The ds has more power...it's rated at 12.6v and the ts at 13.8v... I had the the ts400x4 though and it a good little amp
IndySlim
CoolAssDude
IndySlim
Omaha NE
Kapet
