Top suggestions for 4ch SQ amp
Look for an amp for front stage. Running Focal ES 165KX2.
One of these two might work for you! Both are pretty compact.
I'm liking that AudioControl D-4.800. I can remember the days when AudioControl was the only X over anyone talked about and the Epicenter revolutionized the industry. My only thoughts now are. Do I go D-4.800 or D-6.1200? Was going to ad an AudioControl LC-1.800 for Subs. Looking at the D-6.1200 run in 5ch seems as though I get the same 4x200 at 2ohm plus 400w for a sub. I think if I only do 1 sub this would be fine depending on the driver of course. However if I do a pair of subs I'm thinking running the additional LC-1.800 would be the way to go. My thinking is with that much power for the front stage I'd want more output from the sub or subs than 400w would produce. This also has to do with what sub I select as well I know. So I'll roll this into what sub to pair with either or the LC-1.800 or the 5th channel at 400w from the D-6.1200? This will be going in a Toyota Avalon. Wanting to add the sub or subs in the rear deck where the factory 6x9s are located. Im thinking 10" is the limit. Thinking one 10 won't be enough 🤔 precisely why I was leaning towards more power for the sub channel.
Looks like solid options. However I should have stated I am looking for subs requiring much less power. Typically 400-500rms. Not wanting to tax the stock electrical system or ad a battery.
CAF, Williston Audio Labs(Old School Car Audio) and Jonathan Patrick's Brand X videos when I'm trying to wire an alt into a newer vehicle I...
16
10
738
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
569
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
You might get some inspiration from the install that I did... Delta Audio Install
Fukyourfeelings
Fukyourfeelings
dsw1204
    Jun 1, 2024
    May 31, 2024
