Tweeter Fuzzing/ White Noise Problem
Kickerf150
I just purchased a kicker speaker system. 2 6x8 front door speakers, 2 tweeters, and 2 crossovers
I installed them yesterday and immediately noticed that when the volume is low you can hear a buzzing noise coming from the driver side tweeter. Also about ever second there is two pops. This is very annoying and it only happens to the driver side tweeter. Any help is appreciated.
Could be blown. Could also be wiring. Check the tweeters wiring and see if its shorting on any metal. If you have a Dmm. Find the resistance of the tweeter. It should be the same as the other tweeter
Can't see how the tweeter could be blown as the fuzzing started Happening right after then install. There is also a quiet wave of static that happens about ever other second, could the crossover be bad?
Checked the wiring, nothing wrong there. I plugged the old tweeter back into the crossover and heard the exact same buzz so It can't be the new tweeter. Has me thinking the problem is in the crossover, could it be bad?
Try swapping the left and right crossover. If your right side starts buzzing, then you know its the crossover.
---------- Post added at 11:58 PM ---------- Previous post was at 11:58 PM ----------
Also when you reply. quote. So i/anyone else remembers to respond
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
306
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
887
Tons of options in that budget, including the cost of installation,
10
826
It'll look like a "Hawaiian professional" did your install then 🤣
17
Kickerf150
Kickerf150
San Antonio
The Camry
    May 19, 2024
    May 19, 2024
