two mtx 9512 how many cubic feet (building box for first time help!)
  • 2
pyrothug434
chicago
ok so im planning on getting a second 9512 but would like to know what kind of air people have given these things and came out with good results.
pretty much i have a 99 saturn sl2 trunk is small and i would like some help with box design becuase i would like to give a shot at building my own box with port for the first time i would (exact specs on how to build box)
any help would be greatly appreciated
For those subs, you will be lucky to get two in there and with the proper airspace and port. you should just use one sub in a box about 2.5 cubes (after displacment) tuned to 34 with about 80sqin of port? Adding a second sub means 5 cubes to put in small box. REalistically it will be like puting a 6sqft box in there...
i have one right now and its nice and all but so ur saying it wouldnt b worth it to go with two?? i should just stick with one and give it like 1500 clean power at 2 ohm bc if i got the two i could wire down to 1 ohm and give it around maybe 2500 ... but the box i have my single 9512 right now is good but ya it does take up a little more then half of the space from side to side
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
765
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
pyrothug434
pyrothug434
chicago
pyrothug434
    May 16, 2024
    May 16, 2024
