Viper 5101 Aux Button Problem?
  • 3
Hello-
I am trying to add a OEM trunk release to my 2008 Honda Civic. I have everything wired correctly but I am not getting a signal from my Viper 5101 starters red/white wire to activate the trunk release. I know this because if I touch a seperate wire from a ground bolt to the alarm/relay connection, everything works as it should.
When I hold down the aux button, it just unlocks the drivers door only, does not lock it or do anything else. Is it programming issue with the alarm, a valet switch issue, or wires crossed? backfeed or something? I didnt install the starter.
Finally, any advice as to where to power this? I have the relay close to the starter brain above the pedals-t tap or add a circuit perhaps? any wire in particular?
Thank you so much.
Well first the AUX button is designed for some auxillary function. Holding down the AUX button for ~5 seconds should active the trunk release. the AUX butoon SHOULD NOT control the lock/unlock that's done by the first two buttons on the 5101 remote (the lock and unlock buttons).
There's no need for a relay to activate the trunk on that car. It's a straight (-) input which is what the red/white trunk release wire from the viper is....
Needless to say I'd retract the "everything is wired correctly" statement as it seems like there's some issues here.
And what relay are you pulsing....
피크를 사용하지 않을 계획입니다.
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
They are. But, after using sort of them, i think best way is to root phone and do some real system modifications with Viper.
12
rraabb11
rraabb11
beverly hills, ca
rraabb11
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
