Viper V5701 problems
  • 3
emmd2001
Hi all -
I have an after-market V5701 installed on my vehicle. Until recently, it has been working fine.
Now I am having some issues. Hopefully someone on here can help me out!
1. After issuing a command, and getting confirmation on the remote, the remote gives a series of 2 low-pitched beeps and flashes the red light. This continues until I press another key.
2. After hitting any command, I now get a repeat chime (like I'm pressing the key again) before receiving the confirmation chirp for the respective command
3. I can't get the rear defrost to come on - I just get an error tone now
4. After unlocking the car, the car gives the standard 2 chirps, then pauses, then gives an additional single chirp.
Thanks for any help you can offer!
System has been installed for ~ 1 1/2 years and was fine until 1 week ago.
Not sure if somehow setting got changed by pocket-pushes on the remote (and if so how to fix them!) or something else...
lmao to the faulty brain/bad install comment. change your batteries in your remote. all of these beep notifications are telling you the batteries are low //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
btw the 2 way remote takes 2x 2016, the 1 way takes 1x 2032
피크를 사용하지 않을 계획입니다.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
884
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
851
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
emmd2001
emmd2001
United States
NFrazier
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
