voicecoil wiring options
my amp says its 400rms @ 4ohm n 600rms @ 2 ohm. does that mean it gives out more power when its connected as 2ohm? if it is, must i go get 2ohm woofers?
so what if u have a dual 2 ohm sub and a mono amp that is stable for 2 ohm and i want it to be 2 ohm the diagrams show a total of 1 ohm and then 4 ohm loads so if i want the amp to have a 2 ohm load then would i buy a 4 ohm speaker that will equall 2 ohm to the amp? i thought u had to match the ohms up and the lower ohms the more bass u will get. so then what combo should i do?
ps> im getting 1 sub and a mono amp.
as for your setup, 2 dvc 4s will equal a 1 or 4 ohm load.
1 dvc 4 =2 ohm load.
the lower ohms, the more "wattage" is available due to less resistance. amps don't put out "bass". the sub does.
yea, i don't see how the charts are that complicated.
seriously dude. it just drives me crazy. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
but i think they all expect us to "spoon feed" them..//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
^^got it.. i made a mistake buying a 4ohm sub. gotta go get those other ones. ugh....hate changing stuff n trying to sell the old ones.
i was just wondering if i could wire my subs like this :
so i can obtain a 4 ohm load , the subs are in two seperate boxes
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
415
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
488
548
488
paikiah
Wangaholic
paikiah
Seoul, Korea
tomi
    Jun 1, 2024
    May 31, 2024
