Wanting to get the most out of my PA mids
  • 1
dudeogo
Actually a Potato
I've got 4 unlawful sounds 8s and 4 unlawful sounds bullet tweeters im putting in my mazda 3, with the plan to buy 4 more of each. Currently have 1 machete 80.4 and will be buying another for the next 8 drivers. What should I do to get the most volume possible out of these speakers? currently have one set in the rear infinite baffle mounted on my subwoofer enclosure and they are doing good but I feel as though they could be doing better. Unlawful said I could do a 0.5 cube box each sealed, would that increase output over IB with these type of drivers? Also my door panels are incredibly flimsy. what can I do to not only reinforce the panel, but still keep it light weight and easily able to remove the panel for repair work.
Plan is 2 amps, 2 tweets and 2 8s per front door, a tweet and mid in each rear door, and 2 tweets and mids in the rear mounted on/near the subwoofer enclosure.
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
I agree with DJ. Pro style speakers are designed for large ported enclosures and lack bottom end without an enclosure. Plus they tend to suffer...
8
I think you need like a 10x switch on an amp? You would need to bandpass the mids or something Pioneer network mode or similar? I know the new...
I have ran the 6.5’s, but not the tweeters. They were very smooth and had good low mid bass. They were perfectly happy being high passed at 75 hz...
dudeogo
Actually a Potato
dudeogo
Springfield, Mo
dudeogo
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
