weird battery situation
  • 1
Beatin'
16
MI
I have 3 batts paralleled together. 1 under the hood, 2 in the trunk.
Whether I use a charger or have the car running, the multimeter shows over 14v for the battery under the hood, but like 13.x for the batts in the trunk. The battery charger I have on boost mode, the battery under the hood shows charging at nearly 15v, while the ones on the back are charging at like 13.5-13.8.
What is going on? Too long of a power wire to the back? Bad ground? I don't understand, it was fine all summer, then I had to take it to a shop for engine trouble. 2 months later I get the car back and the batteries weren't fully charged, been sitting in the lot for a while. Sound system kept reducing volume because of low voltage I assume. So I charged the batts and things got better, but after a few days, back to the same problem.
I'm guessing the batteries in the trunk are in bad shape. I spent days desulfurizing them months ago before I put them in because they were sitting in the garage for over 4-5 years without being charged. Maybe the 2 months the car was sitting at the shop caused sulfurization again. Or could it be something else? I dont know....🤷‍♂️
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
Beatin'
Beatin'
MI
Beatin'
audiobaun
    May 19, 2024
    May 19, 2024
