Weird issue
  • 2
sj78
I have a new head unit. Soundstream VR-65XB. Everything is wired up properly however the radio will sometimes lose its memory. It doesnt happen every time the car is shut off. I have tested the constant power and its getting 12 volts with the car off. I have also tried 3 different grounds because my car doesn't have a factory ground for the radio so i ran it to the chassis. I am at a loss as to what i can do. Does it sound like a bad head unit? Is there something else i can try?
If you have a spare HU laying around, try it out with that. If it works, then the other HU is bad.
If not, I'd send it back for another.
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
8
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
6
sj78
sj78
Scranton, PA
Boomin_tahoe
