what am i missing my lights still deam bad
  • 5
Do your big 3 and see if it fixes your issue
This is a good place to start. Your stock electrical wires were not meant to accommodate that kind of power for extended period of time.
Also, make sure your grounds are bolted tightly to unpainted chassis. That usually means grinding off the paint down to bare metal. Use the same gauge as the battery connection or larger.
5 times so far and probably counting. How many times are you gonna post the exact same ignorant nonsense, and not actually answer my question...
19
What size speaker wire would I need? would 16 gauge be ok or should I get 14? I definitely want to be on the safe side.
Came across these. Rechargable, so you don't need to wire anything in and have a OEM look. I don't know if they're reliable or anything, I just...
575
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
drityboy561
drityboy561
UNITED STATES
n2audio
RedRyder18
    May 11, 2024
RedRyder18
    May 11, 2024
