What is the problem with this amp ? crossfire vr804
john691
ca
hi guys , ı have crossfire vr804 , wanna ask you someting about this amp , problem started after use this amp in my home with 30 amp smps , ı noticed someting strange , give power to the amp , 1-2 second amp goes protection and 1-2 second later amp works normal , altough ı didnt wire comps , same problem occurs.....ıs there a really probelm ?
TRANSLATION:
I'm having problem with a Crossfire vr804 amp. I'm using a 30-amp power supply in my house to run the amp and I noticed that the protection light comes on for 1-2 seconds but after 1-2 seconds it works just fine. Should I be worried?
TRANSLATION:
thanks man , sorry for poor english
I will have to say you are not giving that amp enough current. Those are monster 4 channels that pull 80a at modest volume. If your only running a 30a MAX powersupply you are tapping it out and are going to blow your amplifier and PS if you keep it up. Do you have some sort of 12v motorcycle battery as a charge source?
Turn the gain alway down and see what happens.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
776
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
723
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
Love the site, arguments over non-issues, not so much. ;)
13
86
john691
john691
ca
Timmothy Web
    Jun 1, 2024
    May 31, 2024
