Ok, here's the rest--->
Richard Clark Amp Challenge-Cont'd....
In addition to these requirements the test will be conducted according to the following rules.
Amplifier Test Comparison Rules
1. To make things easy we would prefer to use high quality home type loudspeakers for the test. If our speakers are not acceptable, the listener can provide any commercially available speaker system as long as it uses dynamic drivers. The actual measured impedance cannot exceed the rated load impedance of the amplifiers tested. If, however, the tester would like to perform the test in a car, we will use a car, however, it will have to be provided by the test subject. For practicality we will have to limit the number of amplifier channels to four or less.
2. Amplifiers will be powered from the same power supply at a nominal 14 volts DC. (any voltage is OK as long as it is the same for both amps)
3. The test can be conducted at any volume desired; however, the amps will not be allowed to clip. In other words, listening volume can not exceed the power capacity of the smallest amp of the pair being tested. (power capacity will be defined as clipping or 2%THD 20Hz to 10kHz, whichever is less)
4. No test signals can be used - only commercially available music.
5. The listener can compare two amps at a time for as long as desired. For practical reasons we would like to keep this at least no more than a few hours. A test session will consist of 12 A/B sequences. Passing the test will require a positive identification of each amp for all 12 sequences. Remember, guessing will get you about 6 out of 12. If the differences are so great, and a subject can really hear the difference, then he/she should be able to do so for all 12 sequences.
6. To win the $10,000.00, the listener must pass two complete sessions of 12 comparisons. Passing the test means 24 correct responses.* The amp of choice can be compared to the same or a different amp in each session - challengers choice. We have many amplifiers in our demo inventory such as, but not limited to, Alpine, Rockford, Kicker, Phoenix Gold, Precision Power, MTX, Adcom, Kenwood, Pioneer, Sony, etc. You can pick any of them or bring your own.
7. All amps must be brand name, standard production, linear voltage amplifiers. This does not exclude high current amps. Amps can not be modified and must meet factory specs. They must be "car audio amplifiers designed to be powered from a car's electrical system."
8. Failure of an amp (this includes thermal shutdown) during the test will require that the test be repeated after repair or replacement or cooling of the amp. This means that the entire test session will have to be repeated.
9. The amps will not be overloaded during the session from either a voltage or current requirement.
10. To save time the listener will have to pass a quick 8 trial session to qualify for the extended 2 session test for the money prize. Any 2 amps can be used for this test. Passing this qualifying test will require at least 6 out of 8 correct answers.
11. The amplifier power up and/or power down sequence will not be acceptable for comparison. (The turn on/off noises of some amplifiers would give it away.)
12. Although anyone is welcome to take the test, only subjects employed in the car audio industry or Car Sound subscribers are eligible for the $10,000.00 prize.
13. Cost to take the test is $100.00. $300.00 for people representing companies. Payable in advance, scheduled appointments only. Done correctly the test takes several hours and I don't have the time if you aren't serious.
* Twelve correct responses in a row is certainly a lot of correct listening but $10,000 is also a lot of money for a few hours of easy listening. The way people describe the differences is that they are like night and day. I would certainly not have any trouble choosing between an apple and an orange 12 times in a row. When compared fairly I believe the differences in amps are much too small to audibly detect and certainly too small to pay large sums of extra money for. If I am wrong someone should be able to carefully take this test and win my money. Even if I am right, if enough people take the test eventually someone will take my money due to random chance. This is the reason for the large sample requirement. If you feel that you can easily pass this test but 12 sequences will give you "listening fatigue" I am willing to modify the requirements. Since the way it is being offered is a challenge and only my money is at risk I am willing to let a confident challenger "put his money where his ears are". If we are willing to make this a bet instead of a challenge, I am willing to drop 1 sequence for every thousand dollars put up by the challenger against my money. This would mean:
____My___________ _ _Your________Trails Required to win__
$10,000 to $0 = 12 Tries
$9,000 to $1,000 = 11 Tries
$8,000 to $2,000 = 10 Tries
$7,000 to $3,000 = 9 Tries
$6,000 to $4,000 = 8 Tries
$5,000 to $5,000 = 7 Tries
$4,000 to $6,000 = 6 Tries
I will not do the test with less than 6 trails. It would be statistically meaningless and reduce the challenge to mere gambling.
-RC
There- are you happy now??? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
-zane
