what should I put here to seal off the trunk?
M@nJo
bay area
The 2 high lighted boxes is an inside shot from the back seat to the trunk lid closed. The 2 gaps are room that reach into the license plate lights on the exterior and other misc. lighting wiring (IE: 3rd brake light). I wanted to cover it up with sound deadner but wanted to check in and see if it makes a difference? I still get trunk rattles from time to time and I believe this may be part of the issue. I have double layers on the lid and single layer on the floor/sides.
If i cover it up, i wont be able to replace my trunk, license plate, 3rd brake lights. ironically, one of them blew.
Pssshhhh, what's more important to you...bass or lights??! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
cover some sheet metel or 1/2" MDF with deadener and then screw it down to cover the holes. That way you can remove it when the time comes...
this... and use some weather stripping on the inside edges of the mdf to make sure its sealed tight. if you didnt need those holes for somthing i would say some expandable foam. it worked great on my car.
Yeah, any big voids you need to fill (that you don't need access to) just buy a can of Great Stuff Expanding foam...**** is awesome, filled my entire trunk lid with it, works great.
The CT's are nice, That Sundown is a a frik'n beast!
7
858
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
715
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
835
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
M@nJo
M@nJo
bay area
Anton Miller
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
