What size fuse do I use to connect my power to my car battery?
  • 3
darkSSide
I keep on getting conflicting advice so I thought I ask.
I have 2 amps one takes 2x70 amp fuses and the other takes 2x25 amp fuses. I am currently running 4 gauge wire but will upgrade to 0 gauge.
So do I add up the fuses and use a 200 amp fuse?
Thanx any help is appreciated.
Could I use a 125 a on the 2x70a?
you could use a 200a on the 2x70a if you wanted to. It's not recommended but it's your setup. The fusing on the amp protects the amp. It does nothing for the wire that supplies it the power. That's why you fuse for the wire so if it pulls too much current through it, it'll pop the fuse instead of popping a fire in your car.
If you're using 4 gauge OFC, use a 150a fuse
if it's CCA, 100a fuse
Fuse anything going to the battery 150amp fuse I would do. if it shorts you saved your battery, and than you look for causes why it happen, if...
8
Same here. Its what my search pulls up, but its all over the place
4
943
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
3K
darkSSide
darkSSide
Magic Mtn,SoCal
Dmac1991
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
