what x-over do i need
  • 6
king ranch
Banned
5,924
fl
http://cgi.ebay.com/PAIR-300-W-PIEZO-TWEETER-DRIVERS-FOR-PA-DJ-HORN-NTD300_W0QQitemZ360081656379QQihZ023QQcategoryZ47092QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/2-New-Quality-Bullet-Piezo-Tweeter-Horn-Driver-Speakers_W0QQitemZ220273341336QQihZ012QQcategoryZ3276QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
i already have the horns just need the drivers whats the better set i know both are cheap but this is for just a little project gonna run them on a sony xplod amp
so wat exactly do i need to prevent the freqs going to the drivers that it cant play
thanks
Those are both absolute crap. Get a real set of tweeters or horns from PartsExpress.
You can't just swap x-overs around like baseball cards into any set of speakers. For a new set of drivers like your doing I suggest seperate HP and LP filters for each driver rather than a unified 2 way x-over. Pick a x-over freq well within the frequency range of both drivers. Probably around 2 KHz. The filters must be chosen to match the impedence of the drivers, and then you may need to add a pad to the horn to match the levels better.
dude , I know you are on a budget, who isnt?
but those first two tweets will sound .....ok at best. Maybe not even that.
Id find a used set of tweets
well wat xover do i need for those seleniums and i am putting them on my flats boat under the polling platform so i can hear music while running full throttle
well the amp i am gonna use is a cheap xplod amp only has a lp and a off setting so if i turn it to off then i cant adjust the freq to the seleniums so i need something to prevent low freq's
well i can just turn the gain down they dont need much to get loud i heard
You use a passive High Pass filter on the horns to block the bass. You use a passive Low Pass filter on the woofer to block the highs. You need a pad on the horn to reduce the power of the horn compared to the woofer or it will sound like a tin can with no bass.
i thought these horns are for only highs vocal range basically i dont want any bass from it period just vocals, i will have mids for midbass and a 12" sub
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
306
691
447
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
497
king ranch
Banned
king ranch
fl
king ranch
