what's cheaper material for a box?
well im going to try and save money and try a build? so im wondering, is it cheaper and or better to use plywood? or mdf?
Use MDF. Its only $30 a sheet. Can get two boxes out of a sheet if they are small enough. I got 2.6 cu ft and 1.4 cu ft both ported out of 1 sheet. So about $15 a box.
3/4 partical board works good alsoits cheaper then mdf
I wouldnt. Less dense the MDF and isnt as strong. You may be able to get away with it, but I wouldn't personaly. If your sub isn't that powerful you can use 1/2" instead of 3/4" which will save some.
so mdf > plywood?
but i think mdf is alot more expensive in my area. i know for sure its no $30 a sheet. plywood is cheaper. and pywood here costs about 60-70 a sheet. :\
so mdf > plywood?
Wow thats pricey I just went out and ordered a sheet for my next build @ my local hardware store and 3/4 mdf was only $24 a sheet.
so mdf > plywood?
You sure your not looking at Birch ply?
idk. i did check the lowes and home depots. and those were their prices on a sheet of fly. but man. if one sheet of mdf cost roughly 20-30. then yeah. ill go for that. and for making about 4 cu airspace with a port. how many sheets do you think i'll need??
I have no experience with them, but it does not look half bad for it's price. Big plus if you can set all features via cell phone. If you do pull...
I am sure there are hard woods that are much denser than MDF. Don’t know if they would be better for a build, but they would certainly be...
24
467
656
dafobbishon3
dafobbishon3
Texas
Lakota
    Jun 1, 2024
    May 31, 2024
