what's the difference between 4 ohm stereo and 4 ohm mono?
the specs on my amp reads
50 x 4 @ 4 ohms STEREO
100 x 4 @ 2 ohms stereo
200 X 2 at 4 ohms bridged MONO
my question is what's the difference between 4 ohm mono and 4 ohm stereo?
None.
Edit: I think we have to know what the input options are.
Are you really under the impression that your stock radio's amplifier switches between mono and stereo based on power needs?
for that i really dont know, but u can test using a DMM an a single 1khz at 0 db, swiching the amp on mono and back to stereo.
i will try that one day.
You must be describing the antenna function which will switch to mono to compensate for a weak FM signal.
No dude... The aftermarket amp that he is trying to install, it has a setting for mono (factory radio), and stereo (aftermarket stereo). The factory amp doesnt need to switch for anything...
I dont know what antenna function you are talking about... My antenna doesnt have a switch //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Usually on a amp a 4 ohm mono is used for a Sub and a 4 ohm stereo is used for front speakers and/or comps
50 x 4 @ 4 Ohm Stereo
100 x 4 @ 2 Ohm Stereo
200 x 2 Bridged @ 4 Ohms
i got this info from
https://www.alphacaraudio.co.uk/ViewProdDetails.asp?prod_code=PON09G000072&Prod_name=Diamond+D3+400.4++Four-Channel+Amplifier+&Search=Y
btw where did you get your stats?? as far as i can tell its a stereo amp not a mono amp, someone correct me if im wrong
4 ohm stereo. two channels. 4 ohm load each.
4 ohm mono, one channel (two channels bridged) = 2 channels at 2ohms each. sums left & right signal.
According to the Taramps site, there are three variants: TARAMPS SMART3 BASS 1 CHANNEL 3000 WATTS RMS 0.5 ~ 2 OHMS CAR AUDIO AMPLIFIER. TARAMPS...
I can hear the difference. A typical component system will have a superior tweeter and crossover, although I've noticed component crossovers are...
Just thought I'd quickly update this thread as it's been a long while since I promised an update, I finally checked the AC output of the speaker...
23
6K
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
266
658
doublevision
doublevision
nj
drpeeb
    May 31, 2024
    May 24, 2024
