Who's runnin' their Eclipse 8455 active?
  • 3
Hoot
I have a CD8455 as a source for my CDT Eurosport braxials. Right now, I am using the Z-series crossovers on them. I want to consider running active.
Does this make sense only if I go w/a three-way stage? Also, I plan on adding the Upstage/Stagefront system to my A-pillars... not sure if this is really possible if I were to go active.
Anybody experience a similar situation?
I'm running my whole setup active the the 8455 as well. Great HU to run active. So yea in order to go active you must to go into pro mode and select 3 way as your choice to run active.
Hey, fellas, I realize all of the above... I guess I am wondering how to go about this if I am running only a two-way set plus sub. In pro-mode, we are really talking a 4-way setup when including the sub (= three-way + sub). Right now, I have only braxials (two-way) plus the sub -- see what I am getting at? Not sure how I would likely best utilize the dsp if running active.
Also, since I guess I really tossed out a two-part question, the issue also includes the the implementation of the Stagefront system off an active setup -- here, I guess I just run the blending modules following the amp and split the two tweeters with it?
Fantastic, then how about some advice for how not to blow my drivers - I just haven't done it before. Do you just set the crossover frequencies on the HU and then wire things up? I mean how do you tune things? Sure, I know how to manipulate the settings, but how does one do this both strategically and safely at the same time? I assume things are set and then forgot - can settings be locked for safety? Otherwise, one mistaken move with the dsp button and pow....
yes , more power, more control, more dynamics, more volume! Go for it!
I am running a 1996 Reference Picasso, bridged. Bridged, the amp is rated for 2 x 100 RMS at 12v; Four-channel mode the amp is said to give 25 x 4 RMS at 12v. Still think active is the way to go? I suspect it is... I am just curious to hear the justification for as to why. Thanks for any thoughts.
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
7
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
4
877
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Hoot
Hoot
Champaign, IL
Hoot
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
