Well the answer is I don't know?? I have a 6 hp Briggs n Stratton lawn mower motor rigged up to turn the 600 amp catapiller alt running to 2 tractor batts. I am using a boss 5k amp (yeah right) running in 1/2 ohm pushing 4 crappy subs. When I burp it it pulls the moter down a bit but not drastically. We are still having trouble with the voltage staying constant at 15v. It's only a matter of time before I get it right. I think it's gonna work I just want to get it working reliably before I try it on a high current amp. But soon I will have a 600 amp 24 volt alt with little to no ampreage drop under heavy loads.How much power does it take to spin those alts though?
It doesn't matter that something is a good idea or more efficient. It only matters what the market values and since 99.999% of vehicles on the road have 12 volt electrical systems, that's what aftermarket electronics manufacturers cater to. It's the same reason why most software viruses are written for Windows and not Mac. More people use Windows so writing a virus that attacks Windows machines will reach a larger share of the market.
All that said, I'm not trying to discourage anyone from trying things. Personally, I think that's awesome. I'm just pointing out why there is such a small market for 24 volt electronics.
Waiting for everything in your vehicle to be shut down at 24 volts in for fire pics
off the engines i work on.....they are making 1000ft/lbs and the alts are putting out 280 amps...using 4 12v batts wired in series for out 24 volt charging systemHow much power does it take to spin those alts though?
