will this be enough to power amp
  • 6
No, the Kinetik line is very simple. The model number is equal to the watts RMS they can handle. The HC800 can only power 800W RMS. You have twice that in just your sub amp. If you have any front stage amps, you need to add those too. So you need at least an HC1800 for the rear, not including a front stage amp.
no, and the HC800 will be good for about 1200rms...
Uhhh no, it is rated for 800WRMS per Kinetik. If they rated it for 1200WRMS, it would be called an HC1200. They have an HC1200 and it is a little bigger than the HC800.
You probably think that the Boss amps are underrated too huh? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
ok so if i added an hc 1400 in the trunk will that be enough along with the alt and the yellow top
The Yellow all the way in the front is going to give you minimal help that far away. It is possible that it would work out fine, but for the $30 difference in price between an HC1400 and an HC1800, why not go the safe route? Do you have a space issue or something?
not really so then i should be fine with an hc 1800 in the trunk
or should i just add one more yellow top in the trunk
Why would you do that? Maybe you just don't like my advice, but I thought I was pretty clear.
If you already have the Kinetik 800 just try it and see.
I agree with this, but I think you will find that it will not be enough. If you already have one HC800, add another one in the rear for a total of 3 batts (one yellow under hood, and two HC800 in the rear).
put it in a setup with 1200rms and I bet money it will work sufficiently //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
and the old Boss amps where underrated //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif duh
Stock stuff was crappy, yes fronts play and I physically removed the factory amp. Also, if all 4 door speakers were running off of 4 channels how...
Not that I like shilling my own sales but I have a badass digital designs 5channel for sale in the classifieds. One of the largest available...
I love Fosgate amps. The old 1500bd amps I had were absolute beasts.
17
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
margahman
margahman
new york
margahman
maylar
    Jun 2, 2024
    Jun 1, 2024
