Will this damage my sub?
  • 2
Reactions
I recently bought an amp and it has a dirty/broken gain pot if I install it will it cause problems like the gain not setting right? I was thinking of just taping it because if I hold it, it plays normal. lol. I tried finding the pot on the internet but I had no luck or if it has is a special name for it and there is another name for it. It says 3b20k
if you can adjust it and it stays put and it doesn't fluctuate and mess with the gain you should be ok. if it jumps up and down and you can't adjust it i wouldn't touch it or id see if you can send it somewhere to get fixed. (if its worth it)
Okay thanks! That was the answer i was looking for. Btw what is the best audio format i should export/listen to? Im trying to rebass by my own so...
It shouldn't doing some second skin or resonix sound deadner on the door panel and door itself will help with that and improve the sound as well...
I have installed a alpine sub and amp, using a line output converter it all works but the bass stays steady and does not change with the volume...
Reactions
Reactions
California
C1500martin
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
