Will this system be ok on 1 battery or do i need 2 batteries?
  • 2
!.beat killer.!
I have a soundstream picasso 2 channel AB amp. Its 540 watts total rms but at 4 ohms its 180 watts rms x 2 channel. and at 2 ohms its 270 watts rms x 2 ch. i will be using 4 ohms. The model number for this amp is pcx2.540. The amp is huge in size it is 20 inches. I just want to make sure that i can just use one battery. Also i think i am going to use 2 12" SOUNDSTREAM arachnid subs that have 250 rms and 500 watt peak. I dont know to much about radio stuff but i just want a little system nothing huge. i would appreciate if someone could tell me if my radio system would be ok with one battery or do i have to have 2. thank you!
how much power you have from the alternator is what counts batteries have nothing to do with it. you could have ten batteries and not keep up with a strong system. you probably have enough power but lets see what car do you have what wires and upgrades to the electrical system?
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
211
615
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
!.beat killer.!
!.beat killer.!
sardis city al
sexy
maylar
    Jun 2, 2024
    Jun 1, 2024
