Wire Comparison
on the rf wire it has pc or pure crystal ofc what does that actually mean?
i found this explanation:
PC-OFC (Pure Crystal Oxygen-Free Copper) Conductors:
Just as any other raw material found in the Earth there are many grades of copper. PC-OFC is the
highest grade (lowest impurity) of copper without undergoing an extremely costly impurity removing
process. PC-OFC has the longest crystals of copper with the least amount of breaks due to fewer
impurities, resulting in a smooth channel for the electrons to flow through the conductor.
but i also found this;
C10100 - also known as Oxygen-Free Electronic (OFE). This is a 99.99%pure copper with 0.0005% oxygen content. It achieves a minimum 101% IACS conductivity rating. This copper is finished to a final form in a carefully regulated, oxygen-free environment. Silver (Ag) is considered an impurity in the OFE chemical specification. This is also the most expensive of the three grades listed here.
C10200 - also known as Oxygen-Free (OF). While OF is considered oxygen-free, its conductivity rating is no better than the more common ETP grade below. It has a 0.001% oxygen content, 99.95% purity and minimum 100% IACS conductivity. For the purposes of purity percentage, silver (Ag) content is counted as copper (Cu).
C11000 - also known as Electrolytic-Tough-Pitch (ETP). This is the most common copper. It is universal for electrical applications. ETP has a minimum conductivity rating of 100% IACS and is required to be 99.9% pure. It has 0.02% to 0.04% oxygen content (typical). Most ETP sold today will meet or exceed the 101% IACS specification. As with OF copper, silver (Ag) content is counted as copper (Cu) for purity purposes
The high-end speaker wire industry markets oxygen-free copper as having enhanced conductivity or other electrical properties that are significantly advantageous to audio signal transmission. However, conductivity specifications for common C11000 Electrolytic-Tough-Pitch (ETP) and higher-cost C10200 Oxygen-Free (OF) coppers are identical.[8] Much more expensive C10100, a highly refined copper with silver impurities removed and oxygen reduced to 0.0005%, has only a one percent increase in conductivity rating, insignificant in audio applications.[8] OFC is nevertheless valued by some for both audio and video signals in audio playback systems
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
358
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
808
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
822
CrazyKenKid
CrazyKenKid
Canada
JohnFoster
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
